Building a Z22NES
chribo
Thank you Dave :)
Heare is the work of yesterday:
Gearbox before cleaning:
Gearbox after cleaning:
Fitteted also the clutch, flywheel and the gearbox to the engine. The starter and the oil coller got back in place too.
And my last work yesterday: Removed all the rust from the axle and painted it again:
i have a question ?
did you have to get the rod bearings machined to suit the fillet on the forged crank ?
chribo
Hear are some new pics from the last days:
Engine Bay before painting:
Engine Bay after painting and it looks so mutch betther:
The loom of the Xenon lights witch i fitted a few years ago. Its ok but dont looks realy nice:
I fitted the loom new and i think this looks mutch betther:
chribo
The work goes on...
The new belt without a/c
The new crank trigger wheel
Gen 2 oil squirters:
After fitting the oilsquirters i finally closed the engine. Now i onely have to finish the wring and the coolant :)
I like the trigger wheel and sensor. Very nice work
did you have the original crank pulley machined to loose the bump? Looks very well put together.
chribo
Thx, yup it is machined otherwise i cant fit the trigger wheel. Also i tried to make the hole thing as light as possible. The crank pully + the trigger wheel are onely + 0,15 kg and ther is no other trigger wheel inside the block so i saved a lot of wight :)
chribo
Thx for that Carl!
Now the next Update:
Prototype for the battery/ecu/fuse bracket:
Modified Engine coolant module:
before:
a look inside
and when the work is done it looks like before :)
