alarm help
Mark Dj
Or remove the power sounder from the passenger side wing, it needs to be removed anyway for the new one. It's an easy enough job to remove it. It sits behind the plastic guard inside the arch on the front. It may stop even if you unplug it?. Your normal alarm will still work this way (horn alarm) as they have a horn alarm and siren standard.
Mark Dj
Yes, no problem at all :). You will just not have that second noise when your alarm goes off.
Mark Dj
Cool. You will have to push the little gromit things in to remove the wheel guard. You should be able to get away with only removing a few of them, and not all of them to remove the power sounder.
Baz
thats it out 20.gif neigbours cant complain anymore have to get some clips from vx though anyone know how much ill get them when the new batts arrive
Mark Dj
The clips are cheap mate. About £2.00 for about 10 new ones :). Glad you got it out ready for the new parts...
Baz
cheers m8 gaz aswell i get the clips from vx tomorow do you know the part number s by any chance the vx dealers part desk beside me arent very bright :D
Baz
help again guys just got home and checked the new batteries but they are diffrent they have blue caps on them and pcb plugs on the bottom but are the same number on the invoice
Baz
[/img]
Gazza
to be honest mate im lost,by what it says on the website the old style were low on stock so i take it thats the newer version,but i have no idea if it will work i there,sorry cant be of more help :oops:
Baz
ive broke the 3 clips they fit fine same 3.6v and 120mah so ill test it out dont work then dont work lol
Gazza
nio mate like i said mine has been fine ,so i have never took it off to replace i got them as spare know. if i can remember where they are :LOL:
