yes 800 grit and a solid block
its alloy on alloy and its the same head that came off the block
thats what the head gasket is for i dont need to worryHow bigs the block? If it isn't larger than the entire head you are never going to get it the same all over and just hoping the head gasket levels everything for you.
so i take it you two both take your blocks for skimming also at the same time as the heads
