out radiators, cylinder head, alternator, compressor.
You can block out without removing gear box?
I read a post by vocky says 80kg weight. two guys up, you can remove?
I need advice.
results in two hours, between two friends and some brute force outside block.
work harder crankshaft pulley was removed without removing this block does not come ...
