Hi all
New to these forums but thought I'd give this a go. I have a VX220 with the Z22se engine. A new noise has reared its head, sounds like a trudling coming from the engine bay. Noise can be heard when in gear and clutch peddle is released, but the noise goes away when the clutch peddle is pressed.
I've taken it to a garage to have a listen and they think either gearbox oil is low or the input shaft bearing is on its way out.
2 Questions. Would an OBD2 show any fault codes to diagnose this? And do you know if there is a how to guide for removing the gear box?
Cheers
James
Cheers
James
