astra22bertoneauto
What are you going to do with the PCV? The TIG has a different layout for that and I think your manifold will not support it?
PCV? sorry could you expand on this?
The TIG was minus 1 bolt hole but it does not make a difference as long as you get it secured on all other bolt holes. You will need to find longer bolts if you use the Courtenay gasket. I used some bolts from a spare set of cam cover bolts i had laying about.
