help with part numbers
Pleomaxx
hello guys.
i have a z22se engine im looking to rebuild all original but i cant seem to find the part numbers.
so if anyone have the part numbers for original crank bearing and rod bearings
any curious where do u find the part numbers ?
would you change the lower bolts used to assemble the 2 lower parts ?
and last
of you where doing a rebuild like this any minor improvements you would do when it allready is taken apart ?
like thicker head gasket( if it makes any difference) and so on it just have to be cheap since its a low budget rebuild.
Pleomaxx
perfect site just what i was looking for :D
i have already removed balance shaft
any chance you have a simular site with all torque settings i need when assembling
im kinda nervous to assemble it i recived the entire engine dissasembled and 8 boxes so it gonna be fun :D
Okay ive now seached ebay.co.uk and .de with the part numbers from the site you linked and i cant find any of the bearings i need ? any idea what im doing wrong ?
Unfortunately many of those part numbers have now been superseded with new ones.
Do you require standard size crank bearings and rod bearings or u/s 0.25mm or u/s 0.50mm ?
Pleomaxx
im taking my chances and buying standard since i need everything done in a weekend and the crank will be pulled out from a running engine witch never have been opened
Pleomaxx
Okay i am now inspecting the oil pump wich looks fine and now im wondering Should i give it some gansket or is it suppose to be metal against metal?
And anyone with an Idea what the tap in second Photo is called i cant find One but need it for ny rebuild
IDI AMIN
Pleomaxx
perfect i called my local opel stealer they said they couldnt get one kinda strange for a autoriced shop
thanks for the help so far there is proberbly gonna come more questions :D
Pleomaxx
Just Got the head back from wash i got washed 3 times 1 with just water 1 with some kind of soap and then I soaked it in engine cleaner for 30 min and back in with clean water and it still looks Really dirty
