hello guys.
i have a z22se engine im looking to rebuild all original but i cant seem to find the part numbers.
so if anyone have the part numbers for original crank bearing and rod bearings
any curious where do u find the part numbers ?
would you change the lower bolts used to assemble the 2 lower parts ?
and last
of you where doing a rebuild like this any minor improvements you would do when it allready is taken apart ?
like thicker head gasket( if it makes any difference) and so on it just have to be cheap since its a low budget rebuild.
and last
