Guys 04 Linea Rossa
guy 27
Should start a build thread for this one as lots will be happening over the next couple of months.
Car at the moment is completely standard.
Heres a photo of it the day it arrived. (ran out of petrol 3 meters after getting off tow truck. Engine decide not to want to run after about 2km of driving around the yard)
To do list:
Engine:
remove and replace with lower km engine. all seals and gaskets
port and polished throttle body
egr removed
pre cat removed
complete cooling system (hoses and radiator)
Gearbox:
Replace with 4.17fd gearbox
New clutch and slave
m-tech short shifter
Brakes:
new vxr 321mm front brake upgrade
new discs and pads rear
Suspension:
Bilstein b12s (unsure if i'll use 50 or 30mm drop on front)
Whiteline castor bushes
Eibach Camber bolts
I have a rear sway bar but am unsure at this stage if it will be fitted.
Wheels and tyres:
Alfa 159 17" wheels (inc spare)
Michelin Pilot Sport 3 tyres
Exterior body work:
Astra turbo front bumper with washer jets
OSV grills for bumper
DTM opel bonnet grill
Rear Opel emblem
Respray front bumper, bonnet and rear bumper.
Full cut and polish.
Interior:
New handbrake and gear gators
Retrim steering wheel
Retrim front seats
OEM alloy pedals
Alloy door pins
Satnav console (already painted metallic silver)
ICE:
All alpine
CDA-137ebt
PXA-H100/KTX-H100
type r splits up front
type r coax in the back
Pre wire car for sub.
Lights:
New standard headlights
Fit auto leveling system
Hid's in foglights
upgrade interior lighting to leds (inc footwells and boot)
Once the car is complete to my standards I will drive it around for a bit and then make a decision whether to keep it or sell.
guy 27
Wheels.
Sound system parts have all arrived
Suspension was picked up last weekend. then shipped from melb to bris. arrived today as well.
Will be 30mm drop all around with bilstein B8's as after driving my car around melbourne with 50mm drop on the front its just too low to go anywhere.
guy 27
Engine out.
Engine bay washed.
Subframe washed
Polished exhaust shields
Painted vxr calipers and discs. (opc logos inside discs in blue)
Fitted headlight level sensor to rear beam.
A couple of pics. (exhaust system will be changed once car is on road)
guy 27
Engine is back in the car.
Decided to keep original gearbox as I don't have the time to open and inspect the 4.17fd box.
Here a quick pic of the engine before it went back on the subframe. (a few spares in the background 3 engines and 2 gearboxes)
guy 27
Here's whats left to get done over the next couple of days.
Engine:
Install new coolant hoses
Gearbox:
Driveshaft seals
Brakes:
fit fronts
Suspension:
Fit front suspension with camber bolts
Wheels and tyres:
Exterior body work:
Rear Opel emblem
Interior:
Fit seats and steering wheel when they are finished being retrimmed.
ICE:
Install speakers
Run amp wires
Lights:
run power cable to interior footwell leds.
