fixing the 2nd insignia 2.0t 4x4
after picking up an accident damage 2011 insignia 4x4 1 of 10 now 1 of 8 i decided to fix it up and use is as daily car
here are lots and lots of pic from the last couple of months
C__Data_Users_DefApps_AppData_INTERNETEXPLORER_Temp_Saved Images_30728725_714313705627053_2292...jpg
it came on the back of a truck with to my only surprise a gen3 block the LDK engine
lots of little bits to fix
holes and scratches on most panels
had to cut the tyre off the wheel to drive it off the truck
it was pretty beat up
lower wishbone bent
main cooling rad poped
10ton jack kit pushing it straght
getting close
very close to the original position
long way to go
plenty to do on the inside to
a very good friend of mine called me to say he was breaking an insignia so i rushed up there to scavenge some parts
took the trusty plasma cutter and bought the front corner home
at least if i needed any metal parts i have all the bits to replace the damaged parts
bumper headlight and a long list of parts in stock and ready to be fitted
diesel a/c pump to replace the one i used for the astra
crash bar and the extensions
inner tie rod was bent so that got replaced
as the car was ex police i took to decommission it as a police car and removed all the extra wiring
getting there
replaced the broken headlamp plug
even more wires
took the seat and carpet out then wet vacced them
chop chop more wires coming out
replacement door on
a complete car again on the outside
stud welder to try and fix the sil
close but no cigar
5 control units hidden in a bracket behind the dash
i guess that all of it
engine bay cleaning
that will do me
more carpet cleaning
found enough change in the car to buy a new front number plate
back seats were a mess
up front looking better
back seats now clean
took the blue light out the head light then sealed it up
serviced the haldex clutch
normal dirt in the case
didn't have time to wait for a new filter from europe so cleaned it out
had enough oil left over from doing the other diff
new cabin filter and aircon bomb to freshen the inside up
also got the dvd800 head unit the car never came with a radio just got to get this one decoded and recoded to this car
nearly time for mot
it passed the mot and then got a replacement bonnet
even got a different bumper without the anpr holes in
front pads were past there sell by date so stripped the twin pot TRW calipers and cleaned them up
disc hub and edge painted to give it the fresh look 337mm discs :)
genuine TRW pads altho not the TX range
sliders were bit dry
i do like a clean set of brakes :)
WP_20180710_13_54_37_Pro.jpg#
WP_20180710_15_18_35_Pro.jpg#
drivers side looks like it had a sticky pad
before
WP_20180710_17_32_09_Pro.jpg#
after
after after
now on to the body work the police aerial had to go but put a blank in a welded it in place
what hole lol
quite a few dents in this side
trying to keep the body line
other side was even worse
guide coat to find the dips and bumps
like that
nearly done
rear bumper had a nasty score mark
plastic filler
prepping for paint
colour going on then top coat
nice!
at 1st i thought the back end was bent turns out i had not fitted the bumper in the slot right DOH!
moving onto the rear quater
thats made that bit look great
pretty close match to the original paint
and at least its shiny
now to fix the dented sil got a whole sil as a replacement
rear door off for better access
chop chop
the door jam was bent in a little some angle iron show the extent of the damage
not any more
repair patch cut from the replacment sil
made sure it all lined up
inside was cleaned and painted with cold galvanizing paint
factory stone guard removed
test fit
tacked in place
fully stitched in the weld sits under the rubber door seal
WP_20180722_21_28_43_Pro.jpgWP_20180722_22_01_35_Pro.jpgWP_20180722_22_20_41_Pro.jpgWP_20180723_08_29_13_Pro.jpg
under side welded the same
upol #10 stone guard applied to match the factory stuff
cant wait to get this full side painted
more soon :)
had a run down to portsmouth to fix a z22se in distress
loaded up the huge boot let some air out the tyres
after a good run down even with the boot full it managed 36mpg the same day i drove over to perranporth but got excited and hit the sport button the mpg soon dropped down to 30 but was worth it :)
now im back its time to do more of the body work
dinks in the door done
reshaped the arch also had a bit of filler that didnt go off so dug it out
drivers side dings
passenger side almost ready for paint
dings on the door look to have gone to
looking good, I like the new wheels :D
had to borrow them from the other one there worth more than what i paid for this one lol
Just needs some leather seats or some nice Recaros :love:
i had looked at a set of vxr recaros but there horrid looking and almost 1k to buy the seats that are in are great did 9 hours behind the wheel last friday and never felt fatigued at anypoint.
need to fix the dash loom and get the dvd800 recoded can't seem to connect to the head unit thru the obd port
the black bonnet is now the right colour inside and out :)
did a layer of primer
guide coat then flatted it back
paint went on a little dry and thing my gun was dirty got a few stripes
out the gun finish was good on the laquer
car has faded over the years soon be one colour once i get the sides sprayed :)
bumper and mirror covers time for paint
stripped the bumper to the bare shell then washed it clean
loads of bit to come off
quite a few nasty marks to fix
bumper filler and high build primer
same for the mirror covers
base coat on
laquer
grills reinstalled in the bumper
wings are now off ready for prepping and painting today :)
drivers wing had some damage the hammer and dolly got most of it out
prepped all the panels with 180 grit on a 70mm da
high build primer and guide coat
glad to have kept the shape of the drivers wing
after wet sanding
base coat and lacquer going on
again the out the gun finish is great
after a few hours when they were dry the got refitted to the car
took ages to get the gaps right
im not unhappy about how the wing came out considering the damage
recap before and after :)
vx-chris
Its been a while since ive posted on here but ive been reading loads. Ill tell you what Carl you have done an amazing job on this (and the others you have done). Is the astra on the back burner now?
When can i book you in to spray the zaffy lol
That's some good work there Carl. Are you painting all the panels outside?
thanks :) yes with every panel marked in some way all the out side will be painted it will also make the car one shade the new paint is slightly darker
thanks ive had fun working on it :) the astra is at the run-in stage its all back on the road now just need to get some miles on the engine then finish the mapping part
not sure i want to start doing spray jobs lol
some more ground covered with the insignia
windows tinted
rear one needs doing again only had a hair dryer to shrink the film ive now got a heat gun
had a road trip to manchester to fix a z22se with bent valves i was happy with the 39ish mpg :)
picked up a new gaming laptop and a vxdiag unit with gds2 and candi tech2 at least now i can read and clear all errors on the multiple canbus lines unlike op-com and tech2 and its wireless :)
stripped the silver door ready for the colour change to sliver lake
prepped and clean
basecoat on
handles done
front side done in basecoat
bit of a shine :)
nice and easy to refit back to the car and self aligning no need to readjust the catches or hinges
same treatment with the back door
not bad i guess hehe
drivers side got done the next day and missy the new romanian rescue keeping up her photobombing practice :)
i need to do the sil,rear quarter and the top of the boot lid the paint is not quite the same match from the 2nd 1l tin
morphy checking out the shine on the passenger side
primered up the rear quarter this was the worst bit but as you can see with wet paint on the shape is real good very little work needed now before base and lacquer can go on
done some more bits to the 2nd 4x4
modded a battery cover to suit
decided to retrofit bi xenons
decomplind the loom
afl controller and wiring for the front and rear level sensors
replaced the whole front bay loom
adding wires in
bcm
lights didnt work so swapped some wires over to see if they did
old fron bay loom
then a loss of all function from a broken fuse
£20 later
even bought an eeprom reader to see if i cant recover the carpass code from something
so no ive swapped the looms over ive got no wipers no drl lamps or dip beam/main and the ac fan runs 100% of the time tthe engines running
great fun not lol
you will need a VCI for the lights, I've had to get a couple for my astra VXR - one for the Navi 950 retrofit and another for the Infinity sound system retrofit
I would speak to Rusty on vxoc site https://www.vxoc.org.uk/forum/index.php
He has done loads of programming for me - Navi950, OEM reversing sensors, OEM reversing camera and Infinity
so getting around to a few jobs on this car now i have time
new key from KRP in stourbridge £50 just waiting for it to get programmed in
new a/c rad fitted and prepped vacuumed down ready for a fresh charge now its all working again 4c cabin temp :)
and finally painting the whole side to match the colour after i redid the body work
still plenty of wobbly bits
to big dents on top now gone
fresh coat of high build
bagged and ready for paint
after the 2nd time the lacquer went on had an issue with a reaction so had to cut it back some
overall view looks good
bit of a wash
after a couple of days for it to settle the side new paint is very very close to the original paint on the boot lid
