found in sump
Hi all took off sump today to fix leaking oil sensor and found a couple bit in the sump, could anyone identify these for me?
Front guide rail and mounting bolt by the looks of it.
dont drive your car untill further investigation.
whats miles on the clock? Has it had a chain?
Timbo
Dead right, Dave. With that in the sump, I would expect a lot of little bits around the pick-up filter restricting the oil flow.
Curtis Mcphail If it hasn't had a chain, then that needs doing right away. Get the chain cover off and check ASAP.
Take the rocker cover off n look at the sprockets n chain there, at 170000 its either been very very well maintained or its had atleast 1 chain, so it could be from previous damage.
Iv just found all this in my 6litre sump(glad its not my engine )20150124_144643.jpg
i need to make sure its completely clean before fittting it to my car.
Yeh you can see the top of the front guide with a torch, I think that bit u have found is the top edge of it.
evocarlos is the chain man so im sure he can confirm which part it is.
Id say get the rocker cover off and the side casing so u can have a really good look.
edit... its the bottom edge of the front guide i think so id get the side casing off.
Not a massive job, jack, a good socket set and female torxs, a slim 3/8 ratchet is good to get the tensioner off the alternator belt.
A crack bar for the wheel and crank pulley, or a impact gun.
It looks like the left hand side bit of the top balance chain guide. In Carl's photo in post #5 (block is upside down) the right hand side of the lower guide.
Curtis,
Torque settings for Crankshaft pulley bolt are:
Stage 1: 100Nm / 74lbf ft
Stage 2: Angle tighten a further 40 degrees
Stage 3: Angle tighten a further 30 degrees
Hope that helps.
IDI AMIN
It actually looks like this piece of the balance chain guide. See the triangle type shape its a little different to the tip of the other guide rails and the black rail
And you have a broken bit of thread to remove
Isnt that hole round though?
The damaged piece looks like it has a flat edge like the front guide.
hopefully its from previous damage and wont matter.
im sure we will find out later.
