Dead right, Dave. With that in the sump, I would expect a lot of little bits around the pick-up filter restricting the oil flow. Curtis Mcphail If it hasn't had a chain, then that needs doing right away. Get the chain cover off and check ASAP.
Take the rocker cover off n look at the sprockets n chain there, at 170000 its either been very very well maintained or its had atleast 1 chain, so it could be from previous damage.
It looks like the left hand side bit of the top balance chain guide. In Carl's photo in post #5 (block is upside down) the right hand side of the lower guide.
It actually looks like this piece of the balance chain guide. See the triangle type shape its a little different to the tip of the other guide rails and the black rail
And you have a broken bit of thread to remove
