Re: Fitting the megasquirt ecu
right then (cant post on .org as work is mean lol)
Your fueling will kinda track the torque curve (or prescribe it if you limit things with fuel) until peak torque. Peak torque is maximum cylinder filling of air for the given engine setup, meaning thats in theory the highest fuel consuiming point. BUT after peak torque you are then running in power terms (air consumed in X time) which reduces the explicit fuel requirement, but increases generated heat. Heat generated can be cooled with fuel (stops the exhaust valves getting the hump and leaving) hence why it will sort of plateau off or even increase at the higher loads.
Also as with everthing engine related, its never that simple. In short calibrate to what you want the thing to do and then smooth the maps to make them easy on the eye (That is something the guy teaching me passed on, smooooooth is good once you have the rough point).
As for RR time, I can see the problem in that they wont want some oik on there not using their mapping time money. Got a mate who you can trust to drive EXACTLY how you ask them? IME calibrating on the road is 90% of the work as you ge tto feel the driveability and then the last 10% of bits on the dyno for pub talk
