rik1083
I've been building up to this project for quite some time and have got pretty much all the parts, so I made a start..
new hole in manifold for the megasquirt IA temp sensor. You can use the standard temp sensors but have to calibrate them which I didn't fancy doing really, so I got the proven megasquirt sensors. Drilled and tapped to to 3/8" NPT (quite a weird thread but picked up a tap easily enough)
Same for coolant temp sensor (picked up a spare thermostat housing)
Manifold, charger, ecu, loom and charge cooler piping all removed (going to replace the nasty clear pipes at the same time)
this is what you're left with.. only 22 pins, of which i think I only need to reuse 14. The rest will be connected straight into the ms
relocated relays & fuses.. I hate having these in the boot so finally moved them
