Brakes
ja
Hi all, having a few problems with the brakes on me 150 the rears disc's seem to be doing more braking than the fronts as the rears have worn alot more than the fronts, does anyone know what the problem could be ive bled the brakes a few times to see if it makes any difference but nothing didn know if there was a regulater anywhere ? any help would be grate
Thanks
Ja
blue se2
the rear brake pads on the vectra tend to seiz in the calipers take them out and make sure they move freely.
ja
sdbutler10 said:
the load sensing valve may be sezied on.
check that under the rear axle
Thanks sd, where abouts would it be on the vectra as it doesn have an axle
Ja
ja
Thanks i had the dremmel on the calipers cleaning them out today didn realise how much s##t gets in
Ja
blue se2
yeah had one in today they tend to seiz on get very hot and the pad lining falls off
Best to replace the pins that hold the pads at the same time as these corrode to
