My fuel pump is 8 years old now sometimes it huffs and puffs like a geriatric nun with asthma. Suppose I can leave it as is after all it's not the end of the world to change it. Thanks for your help again
standard webcon part, but you can buy the standard z22se trigger wheel pattern from the states and that also bolts on the same way as the webcon trigger wheel
my latest rolling road graph with the same Webcon itb kit, it had an issue with the crank sensor bracket which restricted bhp to 261.9, another rolling road run produced well over 270 bhp
