Courtenay Sport said:Note: This turbocharger is also suitable as a direct replacement for a ZLET turbo unit that has failed and requires replacement. It is a direct fit and will work on a car with standard software. An ecu remap is not required if being fitted as a direct replacement.
You could quickly remove the bolt to have a look if it's got a smaller hole in the end of it.alanmoose said:ahh crap all i know is the vxr turbo was fitted 10k miles ago...spose theres no way of knowing?
