Zxr33
Afternoon, would like a bit of advice please!
I've just put new timing chains and balance chains , after top end rebuild! Cleaned up valves! New seals head gasket! Ect! After putting it back together and cranking it over it seemed to lack compression! Re checked timing again! Crank by hand seems to have compression! But on the key again lacks compression! Did a compression check and only giving 10psi on all cylinders! My question is , if I've got the balance timing sequence the wrong way round would this have an impact on the timing!? Or not!?
I bought the car as non runner with suspect chain problem although no chain had snapped or was there any damage to the valves! Changed them both anyway just as a pre caution! I've done a few timing chains and heads before but not balance chain so just wondered if that could be the cause!? Although I did follow the Gide to balance chains!
So if anyone has any thoughts on this would be good to hear them! Rob!
