SteveSTelford
Good afternoon guys,
I was driving the Mrs's car and decided to overtake a slower moving car, I used a bit of acceleration to get past - probably a bit more than the Mrs would ever use... pretty much straight after overtaking I got noticed the car was shaking a bit then the engine light started to flash... Got back home and plugged it into my OP-COM reader and it came up with the p0300 code.
I have since changed all 4 plugs and changed the coilpack (the coilpack I sourced from a local scrappy and came off another 2.2 Z22SE however the coilpacks dont have the same part numbers..... would this matter?
I have played about with the injectors today unplugging them one by one to see if there is much difference which there isnt..
Any data I can read from OP-COM to help diagnose?
I have not touched EGR Valve yet as I couldnt see how this could be causing such issues?
What else would you try?
Thanks for reading guys
