Hi all, new here and i need a little help with my vec c z22se
Car has 136k miles on the clock and has always been maintained and ran faultlessly
Last week she started to have a slight rough idle that gradually got worse. Eventually running on 3 cylinders and sounded dog rough.
I replaced the spark plugs and bought a new coil pack and things have improved a lot, although the rough idle is still there but is running on all 4.
Also on hard acceleration she misses every now and then and i can tell its down on power with the hessitation showing itself every now and then. also on the motorway the engine light will blink and then i'll ease off and the light will go out
I plugged my cheap obd reader in and had codes ranging from p0300 to p0304 so ive cleared them and its still the same.
I've changed the coolant temp switch too as i read they can cause problems.
I'm at a loss on what to do next as like most, my funds are slowly being dried up with what not and i need this fixed
Things done
1. new coil pack
2. new spark plugs
3. new coolant temp switch
4. EGR blanked and turned to the side (done last year)
5. throttle body cleaned and all seems ok
6. oil/coolant levels are spot on
I need to get an opcom scanner when money allows this week unless anyone local can help? (Reigate)
Many thanks in advance
Things done
1. new coil pack
2. new spark plugs
