the egr valve is used to lower emissions at certain driving conditions
it is not fitted to the usa version of the z22se.
with the egr valve costing as much as £150 + fitting at the dealers it becomes an expensive 'white elephant' when it fails
blanking off the egr valve can help prolong the valve's life, a faulty valve throws an eml [warning light on dash]
the 'egr cheater' is used to replace a faulty valve
you don't gain any performance from blanking the egr system, but it does stop exhaust gases re-entering the engine [which cannot be good]
It will pass the mot fine without the egr.
vauxhall do remove the egr valve on some cars when it fails, but it depends on the model/year of the affected car :roll:
