P
Polished Bliss
Guest
For the benefit of anyone with hearing difficulties, here is the audio transcript in full; if there is anything else we can do to make our videos more accessible, please don’t hesitate to let us know…
“Hello, this is Rich at Polished Bliss, and in this video I’m going to tell you a little bit about Werkstat Acrylic, and how it’s earned its place as the best selling paint protection system in our store for the last three years running.
The first important point to note is that Werkstat Acrylic is a system. While the individual products can be bought and used on their own, we know from experience that they work best when used together, and in the intended order, which is as follows…
Werkstat Prime Acrylic is the first product in the system, and is an intensive chemical paint cleaner that also lays down a protective basecoat of nano-acrylic polymers. You should aim to use it once every six months to clean and prime your paint ready for fresh layers of protection. No matter how clean you think your paint is, even after claying it thoroughly first, it always draws out more dirt and grime, sullying your microfibre applicator pad in the process!
Werkstat Acrylic Jett Trigger is the second product in the system, and is a fully sprayable sealant that adds intense gloss and long lasting protection. You should apply an initial coat immediately after using Prime Acrylic, and then add a fresh coat or two every couple of months thereafter. Put simply, the more layers you build up, the better the finish becomes, both in terms of looks and longevity. No other last step product we stock is as quick and easy to use, whether in spray on wipe off mode, or in wipe on wipe off mode, as some detailers prefer.
Werkstat Acrylic Glos is the third product in the system, and is an ultra-slick quick detailing spray that tops up gloss and protection levels after routine washing and drying. It’s worth noting that panels don’t have to be completely dry before use, so you can actually use Acrylic Glos to aid the drying process. Furthermore, it can also be used to loosen the residue of Prime Acrylic should you over-apply it and then find it difficult to remove.
The finish produced by the Werkstat Acrylic system is characterised by a razor sharp, wet looking shine and, on metallic and pearlescent finishes, the most intense degree of flake pop imaginable; silvers and greys in particular sparkle beautifully in the sun after being treated with the full array of products. All of this is thanks to the nano-acrylic polymers that the system uses, which smooth the paint surface and enhance the transmission of light.
In summary, Werkstat Acrylic is a complete paint protection system that cleans, protects and maintains. It’s really easy to use, delivers a knockout finish on metallic and pearlescent paints and is highly durable too. If you like your car to look amazing but don’t have much time for detailing then Werkstat Acrylic is definitely for you. If you have any questions, please don’t hesitate to get in touch using the details provided on the contact us page of our website.”
Finally, if the above video has whet your appetite, you can find out more here – Werkstat Acrylic Kit | Best Selling Synthetic Car Paint Protection Kit
Continue reading...
Continue reading...
