John T submitted a new resource:
Vectra B Outer CV Joint inc ABS ring renewal (version 1.0) - Vectra B Outer CV Joint inc ABS ring renewal
Tools required; 30mm deep socket, 18mm socket, 18mm ring spanner, rachet, T bar, large flat blade screwdriver, cold chisel, a couple of wrecking bars, lump hammer, stanley knife, pliers & WD40 or similar. I would also advise the following, a carrier bag (for all the crap), large roll of paper towel (for cleaning all the crap) & a handfull of pvc gloves (stops you getting caked in the crap) & an assistant to step on the brakes as required.
***Please note that this is for renewing the CV joint,...
