Hi my vectra 2.2 petrol 2008 starter smelt of burning during jump starting now its seems stuck are all vectra starters the same. How do i get it of to change it any tips cheers ajn
all z22se starters will fit and so will the B207 saab starter.
there are two types, one is slightly smaller than the other, but I have used both on the same engine and they work the same. I guess it's just two different manufacturers
