nickb777 said:Will try to get some zinc one, since I took zinc out thought that would be the case, doesn't help bank holiday and trying to get this sorted asap.
The one which failed ( second time now) were closest to number one cylinder the one directly over the intake and the one at the side next to it. This manifold DOES have the support bracket as well, wonder if it's pressure with the m6 just not being man enough. was only running about 18psi not certain what will happen with 28psi notsure.gif
cavaddict said:Out of interest, is there any reason not to use stainless bolts?
