Hi all.
I am presently borrowing a 140 sri of a mate while i rebuild my motor after a cam chain incident.
Today i went to pick it up and was shocked how bad the brakes are on it? my brakes will have you kissing the windscreen if you are not careful, this 140's Brakes caused me to panic slightly as i came up behind another car at some lights and nearly took the back end out of it.
I rang the guy who owns it to ask if he has ever thought about putting some new pads in and was told it had had a Full Brake overhaul at Christmas (Pads,Disks,Shoes,Pipes). I went and had a bit of a play with it (bled the brakes etc) and even though the brakes are soft they do work and the sponginess doesn't get worse when you push them and hold it (which kind of eliminates the master Cylinder). I did a bit of reading up and read its possible to be the ABS Module/Pump? if not can you suggest anything else to look at?
Thanks.
Thanks.
