Re: My Z22SE Engine Build
OAKMERE said:
I think it has been worked out that 1.5mm skim would give a 11:1 C/R and a 1mm skim would give just over 10.5:1 CR. Also some of the ungraded valves give a higher compression ratio.
Cheers Oakmere
The reason I asked is that I looked like you were suggesting on an earlier post that
removing 1mm would have equaled the same CR as the YH
Irrespective
20thou (0.5mm) will increase the 2.2 by 1/2 cycle raising from 10:1 upto 10.5:1
40thou (1mm) will increase the 2.2 by one cycle raising from 10:1 upto 11:1
60thou (1.5mm) will increase the 2.2 by one and 1/2 cycle raising from 10:1 upto 1!.5:1
60 thou is the max from the head any more and the oiljet is compromised
for additional increase in CR can be acheived through skimming
upto 60 thou from the block face
I am assuming you meant custom pistons not upgraded valves?
