I bought the 2001 2.2 Vectra on the 11th April 2010 - had been wanting to get back into the Vauxhall club for a little while and had viewed many Vectras. This one is in black with full irmscher styling and only 61k - its immaculate, obviously someones pride and joy. I checked everything over, full diagnostic, body, HPI etc - could smell coolant from the engine bay however thought about pipes/thermostat, valve etc which are no problems so I bought it
Got it home, first thing is balancer and cam chain so bought all the genuine Vx stuff including seals/new bolts and a full service kit. Monday night started by pulling the plugs for a change, noticed some filler on the coil pack boot in cylinder (4?) nearest the cam chain. Either way, this was not going to be pretty - yep cracked cylinder head - looks very much like someone crammed the taper seat plug too tight
Mad scramble and £545 for a new head from ATOM X, full strip down and rebuild with gen Vx head gasket kit, new seals through out - you can read the full story here. (thanks again to ATOM X, great guy and excellent engineer)
Car finally running with new cylinder head and no oil/coolant leaks
