So moving on to the balance chain. I'm getting the kit Monday. I want to get that done before the head comes back so it's one more job out of the way.
Going through the Haynes manual (which has been well worth the £20 so far) I'm reading up on how to change it. I can't get my head around the timing marks on the crankshaft sprocket, inlet sprocket and exhaust sprockets. According to the book, on refitting, they line up with the two silver and one bronze link on the new chain.
The balance chain is running free although with some slack in it. But I'm a tooth missing on the crankshaft sprocket, and when I line the exhaust sprocket up in its sort of 7 o'clock position, both other sprockets are out. I assume they all run equal to each other, ie. they all run at the same ratio, or will the crank have to turn lots of time before all the markings line up as the book shows?
What I don't want to do is take the chain off, move the sprockets to their position as the book says, then fit the chain so the coloured links line up, if the sprockets could be a whole revolution out?
To summarise, I think the balance chain may have jumped. :?:
Any help would be appreciated. Thanks guys.
