z22se-fan
Hi all,
During last mot I was adviced to change the front brake hoses / pipes due to wear and tear and corroding. So I got a set of braided ones for front and rear and installed them yesterday. After removing the old pipes I've put on the new ones, checked all the connections and went refilling and bleeding the system.
Now for some reason I only get brake fluid running through the right rear and front left calipers. The fluid doesn't seem to reach the other two calipers somehow.
Now there's probably an airlock somewhere... I have a pressure bleeding kit (2bar max) and brake fluid remained in the reservoir at all times above the MIN level.
Does anyone have any suggestions on how to get brake fluid running through the whole system?
