From my trawling the internet...
I understand that affected Vectra VINs are LLLLLLLnn[1703 to 1706]nnnn. My part of the VIN is 1710 which seems to suggest
mine isn't affected.
However...
I
also understand that affected engine numbers are those
before 11065400.
My engine number is 11039677 which seems to suggest it
is affected!
You say your chassis # is 11087780. It's looks more like an engine # to me & from the info I've gleaned from the 'net I think your engine was built after the affected batch.
Hopefully someone with infinitely more knowledge will be along soon to help both of us & correct the above info if I'm wrong, as I'm also worried & in need of advice:
My Z22SE Vectra is a (Jan 2002 registered) 51 plate CD auto & (luckily) it runs fine. The only reason I found out about this problem is 'cos it's just come upto 40k miles & I thought "time for a timing belt change" to be informed by my local independant garage that it's a chain (numptie that I am!!). I then checked on Google & found this can of worms.
Given my VIN & Engine # (above) can anyone here help me too, to find out if my Vectra (which I love to bits) is affected?
I've phoned my original Vx dealer that I bought the car from (Network Q) & they have no record of a recall on it (as it's actually a re-work) & also no record of the mod being done.
I've phoned Vx in Luton (quoting field remedy 1532) & they fobbed me off saying there was nothing on their system & telling me to take it to a local dealer for inspection - no doubt at my own cost.
Now I've also heard that if the bolt by the timing chain cover has chamfers on its corners then the engine is OK - but also heard that this may not always be the case. Any input on this? My camera's not the smallest thing, so it was tricky squeezing it in there but here's the pics:
[/img]
