SpaceWalker
Today i finally decide to fit the 2.4 Manifold.
After re-assemble and check all the parts that are in place i tried to run the car.
It started but it keeps holding high RPM (1500) on idle. After 2-3 minutes the RMP drops below 1000, but the engine light appears also with the TC light and the car starts running not stable at all - like choking. No power at all and not able to force it more than 4000rpm. The car is shaking when i push the gas pedal and from time to time i loos the breaks (the pedal become like concrete). After reseting the ECU the problem is not there any more, but again when the RMP drops below 1000 again the same problem. Just fitted the 2.4 and the EGR cheater, but still with the stock 2.2 TB. With the EGR cheater and the EGR the same situation, no difference.
Any idea, i am totally out of such
