Thats a hard one mate, the only way I know others have got through is by drilling a hole. You may also be able to remove a blank bung for a throttle cable and run it through there what.. . I know the Astra has one some place to the drivers side notsure.gif . Drilling a hole ain't to bad, take the glove box out, drill a hole from the engine bay area into the glovebox area or from inside the glovebox area and out. Use a fine small drill first just incase your too far down
no no no theres an easyer way!!!csh.. there is a rubber bung on the left handside behind the shocker mount you can push it out and dill hole in it push wire thru it pops out by the acselerator.... thats how i did mine lol 0gadge to..----> https://i90.photobucket.com/albums/k262/ ... Medium.jpg bit late i konw but may help others
On my Astra, I've run the power cable along the inside of the near side wing, and then under the rubber on the door seal into the car. Not the best way to do it, but it's worked fine for 2.5 years so far.
