if you feel confident and have a SPARE throttle body to play with, you can port the 58mm throttle body
this makes the engine rev a bit easier as the flow is improved
here's a couple of pics of my original 58mm throttle body
the left-hand tb has the shaft flattened, this increases flowrate, but is optional, the right-hand (standard) tb has black arrows pointing to the alloy to be removed
the left-hand tb shows the countersunk screws, these increase flowrate, the RED arrow points to a very thin section of alloy - be careful !
the right-hand (standard) tb has a black arrow pointing to the alloy to be removed
