ported cylinder head
Blue_2.2
will do,
I will get some pics of it as well.
Vocky......
Have you considered raising the compression ratio?
Especially with differant cams fitted, won't they alter the dynamic compression ratio (compared to static) because of the valves being open for longer?
I always consider 'cost vrs power' gains and compression ratios are expensive considering the minor gains
I would not consider a thicker gasket as that changes the timing slightly
I was quoted £25 per valve for a machine shop to fit the valves :eek:
that's £400+vat :eek:
so I found my old set of valve seat cutters and spent hours cutting the valve seats bigger, the kit was for leaded valve seats (which are softer) so by the time I was finished it was terminal :LOL:
my advice is get the standard size head, but Swirled/Waisted stem, the power difference betwen +1 and standard won't be much notsure.gif
the difference between a standard valve and the S/W valve is HUGE :D
