Hi All,
I have a Signum with the Z22YH engine, two days ago it came up with the "spanner in a car" light and immediately went into limp home mode. When I used OP-COM it showed the code:
P1191 - Fuel Pressure System Malfunction
(52) - Present
I reset the code and ran it again, after 10 minutes the light came back and so did the code. I repeated this test a few times ... sometimes it would be in limp mode and sometimes not, but always the same code.
Using advice I saw on this site I thought that because it was still running it could not be the Hight Pressure pump.
Also to start at the low cost end I began by replacing the Fuel filter. When it started after a few minutes it began running really lumpy (sounded like 2 cylinders) the fuel pressure in OP-COM showing less than 400 Kpa and of course the code came back.
Bought and fitted a pressure regulator, the code code back and the engine ran as it had done before fitting the fuel filter (i.e. not lumpy).
Bought and fitted a pressure sensor, the engine is now running really smoothly ... but the code came back and again sometimes it goes into limp mode ... so I am back to square one.
Using the monitoring part of OP-COM I watched the fuel pressure and on one occasion when parked up and letting the revs rise slowly towards 3000 rpm, I saw the pressure drop to something like 300 Kpa for a very short time accompanied by a quick lump in the revs. This immediately disappeared and the engine ran as normal but the code came back.
I made some test drives and on each occasion the code will come back after about 5 to 10 minutes sometimes in limp mode and sometimes not.
So to the question ... am I now only left with replacing the High Pressure fuel pump?
Thanks in advance.
(52) - Present
Thanks in advance.
