vectra_Mike
Right I've searched on here and seen so many different threads to do with the Z22SE using oil like its going out of fashion... Leaking, Burning etc... well I'm having the same issues, seems like I'm having to top up every 150-300 miles, although I have been going from the trip computer telling me to check oil level and then looking at the dip stick reading... The oil warning light on the dash has not come on just the trip computer warning... I notcie I do get some smoke out the exhaust if I get into the high revs, so I know it is burning some some, but a litre every few hundred miles is a little bit excessive.. still judging by the past threads it would seem these engines to have issues with valve stem seals, piston rings etc.. which will burn up the oil...
SO... here's some of the facts I would like to know...
1. Why do the rings seem to wear quicker on the Z22SE then any other engine Ive ever owned? Had cars in the 150K miles and not had this problem?
2. Whats the cost to get piston rings replaced? Would it be a big job? (Engine out)
3. Is there a way of uprating the rings at all? like was there a design fault as they wear pretty quick if thats the case?
4. Is the Dip Stick really usless for oil level readings?
5. What is better oil to use, 10-40W or the 5-30W?
6. Ive read that low oil readings can be caused by a blocked oil pick up, any truth in that?
7. Does the timing chain use oil from the engine to lubricate it?
8. Can you keep running the car with worn piston rings?
9. Will this have an effect on the MOT emissions test?
10. Is the trip computer warning a good guide to go by?
11. Does the Z22SE has a tendency to burn oil anyways?
12. Why do the intake systems seem to get clogged with oil and gunk, is that a sign of aorn stem seals?
Thats all I can think of off the top of my head, thought it might just be handy to get these question and the answers all together on one thread for future reference...
Sorry if it seems like Im asking for people to repeat what they've already posted before but I like to try and get to know my engine in my cars...
