Sorry to be goin on at this time of night. If the blue bits hold injector to the rail what do the metal clips do? Could the plastic part be a locking mechanis to stop the clip coming loose. Or sometimg resembling that?
Went main dealers this morn and the blue clips slide inbetween the metal ones. Bought a clip and injector seals kit for £28. What size is the crank pulley bolt and chain tensioner?
