I'm home
Well the electric window fixing was a bit more involving than expected
The existing omega motors seemed to be fitted strangely..
With rivets in newly drilled holes, i'd already refitted the new motors by this point.
More extra holes and it looks like it has been hammered?
And the loom that's mostly sat in the bottom of the doors
It's a loom from a 92 vauxhall joined to the vectras existing loom
I didn't have a proper vectra loom to hand so the extra wires and connectors were stripped out and the rest taped back up.
Well it seems to work anyway dunno..
The window motors were replaced with vectra ones, riveted into the proper holes and all working showo..
The next job was getting the doors back together
Speaker wiring was a bit easier than the fronts.
No dynamat or plastic sheeting yet, that's a job further down the to do list for now.
I need some vectra switches for the rear doors now, its got cavalier ones in at the moment, still thinking what to fill the hole where the winder used to go with :roll:
Anyway more mechanical things!
With the arrival of the last parts I needed to fit the suspension on saturday I packed the car up and headed to Newcastle to envoy cdx's
Nice smooth tarmac to work on there and he has a set of spring compressors. And vauxhall dealerships if we break something
Everything was new apart from the bump stops and the nut that holds the top mount and the spring assembly together on the damper
The Eibach springs are shorter than the old standard ones, but thicker
This could well be the cause of the odd ride :think:
A few coils missing, not enough to cause any rattles though, No sign of where they went.
I wasn't sure what the orientation of the upper spring seat was meant to be, I put it at its most level and left it at that
Seems okay lol
The hardest part was getting the old anti roll bar link off, the bottom nut was almost off before it jammed up, envoy cdx managed to remove it, it took more effort than it should of!
Everything went back together okay
It seemed like a good time to renew the ARB links.
The bilstein shock absorbers need a hex key to hold the strut while bolting it to the turret instead of the vauxhall 8mm spanner fitment. The plastic caps don't fit any more because of this so i'll need to modify them.
Sitting high, lets see how they settle.
Onto the rears
Plenty of mud to get covered in
There's adjustment in the bolt holes that hold the rear suspension to the body, what's it for?
More parts in the rear suspension
The bilstein dampers are thicker than standard
Seems a shame to put rusty parts back on
The bits of masking tape were wrapped around the spring so the compressors didn't remove any paint.
I'll have to get those bits stripped an painted.
And fitted
All new bolts, although the ones on the rear were in surprisingly good condition.
The eibachs are taller than the standard rear springs
Had part of a coil missing from one of the old springs, not much though.
The old passenger side suspension had an extra lower spring mount too :?
All done
Low at the back and high at the front
I know it needs a wash lol I wasn't expecting the suspension parts to arrive for another few days.
It handles a LOT better, it has a great ride now, it'll be interesting to see how it all settles.
