Well its a month on and finally blanked off the EGR valve 2 weeks ago with the following results:-
1- engine has stopped missing and stopped stalling, put this down to smoking exhaust not being recirculated and chocking engine.
2- about a 10% reduction in fuel economy but well worth it to have a drivable motor. cheers.. cheers.. Vocky
Also, the long term internal water loss, reason never diagnosed, cured by using a seal up additive.
Now 1 month without having to top up.
This leaves the smoking problem. Heavy smoking on cold start up and first 100 yards then after engine overrun after breaking on engine especially after down hill run. Can go for periods when not smoking much if revs kept below 3000rpm. Accelerating above 3500rpm leaves plume of smoke
:evil: :evil:
So suspect valve stem oil seals. Engine fairly smooth when cold but diesely sounding when hot. So what next Vocky?? notsure.gif notsure.gif
