Hi,
Not sure what forum section to put this one under.
When my Veccie was about 12 months old I started to get a knocking noise from the front, not often and not loud, just every now and then. When it was in for it's service I asked the Vauxhall garage to check it and no fault found. This went on and the knocking got worse to the point I started to experience bad over steer (tyres were not bald). So back into Vauxhall and the car was only just out of warranty, what do you know Vauxhall found my front anti-roll bar bushes were worn, "Known Problem" apparently but as my warranty expired I had to pay, even though I argued that this had beeen going on for 24 months (on and off).
Anyhow new bushes and all sorted.
I've now started to get a knocking noise from the back of the car, more noticable if I go over a bump whilst going round a gentle right bend, there is such a bend on my way out of the company car park so I hear it most evenings.
So am I likely to be looking at rear anti-roll bar bushes or are the shocks shot or is the back end about to fall off?
The noise seems to die off after a few minutes driving, I checked the exhaust mounts and they are all ok.
Anyway any thoughts on this ? Anyone else experienced early failure of the front bushes ?
MattP
MattP
