If they are FAI, I'll be able to get them and should be able to do a decent price on them.I bought these, the manufacturer is FAI.
I don't know if they can be had any cheaper through the forum shop though?
I've got 11 (odd number I know) brand new ones here if they're of any use to you
I'll get you a price first thing Tuesday morningOk thanks. Next friday I will be ordering my chain sets, crank bolt etc. If I can buy the lifters through this site that would be good.
Which timing / balance kits would you be gettings? The FAI ones? The kits with the gaskets come with everything you'll need, including crank shaft oil seal.Thanks. Is there anything else I will need that I have missed?
Timing chain set
Balance chain set
Crank bolt
Lifters
Thanks
You should have pretty much everything then.Yes the fai kits.
Thanks
