SuperHeavy1203
Hello,
I have tried searching but alas no joy.
I would be very grateful for a link or steps to remove the inlet manifold on a Z22YH please.
I think the swirl bar or a flap maybe sticking although the bar does move when the engine starts and I can gently push the bar towards the drivers side. However when trying pick up speed I get the change of inlet air induction drone noise but the engine pick up isn't great.
Desired Fuel Pressure and actual fuel pressure are spot on according to Op Com, as are throttle signals etc
Also I'm guessing the knock sensor lives under the inlet manifold? No MIL or spanner light but Op Com says knock sensor is inactive????
And I think the rear O2 sensor is playing up. Op Com shows it inactive at idle and inactive at steady 3000rpm
Thanks in advance,
Andy.
Thanks in advance,
Andy.
