hmm....
Had my doubts before starting it up after fitting them both, as I've never been able to get the timing marks on the chain in the right place at the right time, the closest I had them was 1 link away.
Should I be able to align them? how many turns of the crank should it take to get them aligned?
anyway, had it running for 15 mins.. sounded fairly ok, but it stalled itself then wouldn't start again.
Removed the cam cover again, all seemed ok, but now I could only get them to within 2 links of the timing marks... really need to know how many turns of the crank it should take to get them aligned to look like this...
after I put it back together and started it again (it started once), sounded pretty rough (rougher than before), I turned it off, then it wouldn't start again.
Think I'm going to have to take the timing cover off and check all the timing marks everywhere, would just like to know if it's possible to get the marks aligned with the diamonds, aligned with the timing tool after it has been set up the first time..
Speedy replies appreciated
Thanks
