Already mailed him, as i missed the ending, he is not relisting them for 3 weeks for some reason, did mail him back to ask why, but he has not replied.
- Tighten all bolts to 85Nm (in specified order if specified)
- Rotate all bolts another 30 degrees in same order
- Rotate all bolts another 15 degrees in same order
So basically you are tightening everything evenly in 3 steps.
I am now having trouble shifting the cam crank bolts, even with a mate holding the cams in place and me coming in with the lever bar they just dont want to shift, I think my timing chain recall was done by a gorilla!
Vocky soince you last suggestion worked, any more good ideas
lever bar once again, car in fifth gear, mate pressing brake pedal and handbrake applied, take up the slack until the engine is locked, then slowly apply pressure until the bolt moves, don't try to undo it quickly or the socket will fall off :roll:
