I put my new piper manifold on my VX220 at the weekend and intially it was leaking a bit so I tightened it up whilst hot and seemingly got a good seal but I was worried I tightened it up too much. is that possible?
TIS says use 12nm which is nothing but I can't get my torque wrench in as access is sooo limited.
I just used a standard spanner and did it up pretty tight (didn't go mental and it was only a short spanner 15-20cm I would guess).
I don't want to run the risk of never getting it off again it snapping the studs if I do.
thought I would check to see if it was advisable to back them off a bit before i fit the heatshield...
Thanks! cheers..
(and yes I am completely useless at this kind of thing but I'm learning fast! )
Thanks! cheers..
