identiti66
If you fine sand the LED's it diffuses the light creating a softer effect.. found it better to use flat top ones with 100 degree viewing angle though.
In electronics, a diode is a two-terminal electronic component that conducts primarily in one direction
On the leds with leads, longer one is positive.
Well, You might have gotten a spoilage. Anyway it's always good to check the led if it works at all.
I even can tell poles by looking at the led chip.
