Yes they are all the same on the Z22SE. I'm having a few issues getting to VX to pick up a new batch due to work and home commitments. Monday I'll be able to go and get some more to add to the shop stock.Which blanking plate do I need? Is it the same for all Z22SE engine applications? Mine is a Vectra C.
Thanks for all the help so far guys. One last question......
Is the EGR valve as easy to remove as it looks? Remove 2 bolts, fit blanking plate using the same 2 bolts. Attach EGR cheater to plug and wrap in electrical tape.
Are there any other pipes leading to the engine which require removing, blanking etc? Again this is on a Vectra C.
Sorry for all the questions, not very experienced with car DIY.
