astracook22
opened up my rocker cover yesterday and above cylinders 1 ans 2 was clean and looked like fresh oil
above cylinders 3 and 4 oil looked darker but was still oil there the holes that spread oil over the cams on the top of the rocker cover was slightly blocked but un clogged the doesnt seem to cause any wear to the cams luckly wondering what would have caused this
also my 2.2 choked alot and seemed to misfire on idle after lots of research n her and over site found out they dont like the ngk's and went for the 3 prong gm ones
omg the gapping was hell of alot bigger on the gm plugs
the choking went instantly but still not a bang on steady idle thought a vac leak had injectors out to check O rings all fine
inlet manifold off all rubbers fine used the old carb cleaner trick round the manifold and alll vac line in and away from it nothink at all dissapointing
could a fuel line cause a prob if air was getting in to the line im really stuck wiv ideas and struggling with it after time and money trying to find the problem but dont want rid of the car or engine astra mk4 btw
things ive changed
veccy c intake
k@n filter
coolant temp
number of sets of plugs
coilpack
throttle body
brake booster lead
rear lambda
exhaust gasket
tps sensor
air temp sensor
egr valve (tried blanker as well)
regular service every 5-6 months if not sooner
54 plate got plastic cover even thou documents say z22se think plastic ones are z22yh not sure same thing pretty much
just want a bang on idle idles bout 700 rather then 800 and flutuates bout 50 rpm no eml at all
can hear stight whining only at high rpm think its ma altenator
any advice or opinions would be much appriciated
thanks for your time guys
things ive changed
veccy c intake
k@n filter
coolant temp
coilpack
throttle body
brake booster lead
rear lambda
exhaust gasket
tps sensor
air temp sensor
