Just asking if this kind of heat could've burned through the sheet metal used as a blanking plate, that is all.
If i were you i would disable this function for now if it is possible, And wait until your car is running properly before you have the flame function
The repair shop said that they were changed, but fir the first few days after the repairs my car sounded like it had a diesel engine... jokes aside, I was told than in couple of days they should seat themselves in and it would be better.. but as you can hear yourself after 1000km it's still not sounding great
The tappets should sort themselves out within a minute of the engine running as they should be lubricated by oil to stop them from being noisy.
So potentially the oil is not circulating correctly, if as you say after 1000 km they are still noisy, this could also affect the timing chains as well as the timing chain tensioner which requires oil pressure for it to function correctly.
I would also advise against any crazy driving and racing before you have this problem solved.
If you can, tell us what timing chain kit has been fitted in your, if you supplied the garage who done the work with the chain kit or if they supplied it themselves
How is your work with the egr system going. Have you made any progress?
